Baracus
Anyone know where I can buy race grade Methanol near Randburg/Fourways area? I can get from Trident chemicals in Germiston but its a bit far to travel there all the time, going though this stuff like crazy! :rollsmile:
I've been struggling with some wiring issues on the meths kit but finally think I've got it sorted. The car feels like its running on rocket fuel now, massive difference at the reef! Timing and boost on these Procede maps is definitely set for American high octane fuel, timing curve now starts at 10degrees and goes to, and stays at 15degrees advance through out the run at 16.5-17psi. That was only on a 50/50 mix. To put that in perspective I made 261wkw 606nm at 15.5psi on 95 pump fuel. Waiting try 18psi+, but will use 75/25 mix with some OB. Can't wait to get to the dyno sometime..
