DieselFan
Hi,
So I decided that I would replace my vacuum tank as I am having my turbo serviced and want everything 100%.
So I pulled Realoem up and found the vacuum tank and saw there's a pressure converter in the system. As you can tell I am no expert but I like to learn. So off I went to google.
I found the pressure converter in the boost system has an airfilter inside it. And as you can imagine. Airfilters get blocked after time. I can just imagine after 420 00kms (420...:fencelook: ) how blocked it could be.
Anyway I will be whipping it off to inspect and possibly replacing it as replacing is going to be better than cleaning it depending on the dealer price for the part I will just replace.
Here is the link with a vague DIY for those of you whom are interested.
Pressure converter - Airfilter and cleaning
Part number 1 in the realoem image:
Hope this can help some one.
