Gizmo said:White smoke is actually steam, the coolant is getting into the combustion chamber and turning to steam in the exhaust. Pull the spark plugs and see which one is wet or looks different to the rest, that will tell you what cylinder has the problem.
GPGrobler said:My M40 made sound that too until it cooled down, these engines are tougher than we think, I would not try that with tne newer aluminium block engines though! However if it still makes the same sound if it is cooled down it is crankshaft and/or main bearings.
Lizzard said:On my E36 I had a problem where the car would just die on me while doing nothing (meaning not changing something), I eventually figured it out that the positive red cable on the battery in the boot has been braking away (actually Afrikaner here so I cant get the English word for this :roflol: )The positive cable in the boot was loose and I had to fix that, not at the pool but about 20cm into the body.
Check that first if there is a sudden no dash lights on the car.
moranor@axis said:I think you need a new battery from what you report yes engine will not run without power
How to you pull cable around with the little space in the boot?Lizzard said:Have someone sitting in the car with the ignition on and then go to the back and pull the positive power cable left and right and see if the car does come on. that's how I figured mine out, car is full of carpet and cosmetic things
otherwise put jumpers on the front and see if your lights comes on inside the car that will also eliminate the battery connections to be a problem in the back
CompactM. said:Agree. battery issues can afffect sparking.
Dont forget to get that thermostat replacement before running the car proper.
