Oil Level E90 330d
iceman_997
Hi guys, just want your take on this, I had my car serviced on Friday 12/12/2014. Apparently while they test drove the car, the sump plug cracked and all the oil came out. When I collected the car the oil level is close to the minimum mark according to the computer. Is this normal after a service?
Xeqtr
Aaaah I would take it back and tell them to fill the oil... Whenever I checked my E90 after service it was closer to the max mark...
I would do that just to be safe.
Rayzor
Check your dipstick first, you could have a faulty sensor, if the oil is short insist that they drain it and fill new oil :coolShake:
Speedy
Same thing happened to mine, a reset fixed it or it would have needed a new sensor.
iceman_997
Just to update you guys, I went back to Cedar Isle this morning, the sensors and everything was fine, they topped the oil up with 1 pint. Makes me wonder whether the oil was changed or not...:thumbdo:
