Oil Leak Please Help - Again!
DarrylvanNiekerk
Evening all,
So I managed to sort out the water leak by purchasing a new water pump and thermostat (e90 320i, 2006) - installed both and so far so good.
I carried on with adding fluids so I could get to the first turn over after the engine rebuild and noticed a puddle of oil on the floor. I know I tightened and torqued everything as I went along so could not for the life of me figure out where it could be coming from. After a little tracing I found that oil was pouring out of a threaded hole on the head right next to the chain tensioner.
Under normal circumstances there would be no oil coming out of this hole so no bolt is present and I cannot find anything on RealOEM. My only thought is that the guys who rebuilt the head did not install something and this channel is now open and leaking oil out. I know the head is used on multiple engines in various countries with a variety of hydraulic applications so am not sure how to deal with it.
I looked through my remaining bolt stash and cannot find anything with the correct thread to close this off. Does anyone have any advice or input?
One suggestion is to try and find a bolt with the correct thread and an aluminium washer so I can close it off.
I took a picture of the hole where the oil is coming out of and another with a temporary bolt inserted - I could not get the bolt in further than about 3 turns so the thread is definitely different.
https://www.bmwfanatics.co.za/media/oil-leak-point-jpg.141/
DarrylvanNiekerk
So I am at BMW Midrand and there is a small screw plug that fits in there but because we don't use it in SA there is a 2 - 3 week wait for it...
It looks to be the same thread as an exhaust stud so am going to do a temporary fix until the part arrives.
DarrylvanNiekerk
The bolt supplied didn't work so I ended up finding probably the only specialised bolt shop open in Joburg at this time of year.
Bought an M8 bolt with a 1.0 thread about 16mm long with an aluminum washer.
The bolt was a little long so ground off about half a centimeter, cleaned the threads in the head, put some Loctite blue on the bolt and tightened it to 12Nm - no more oil leak.
I have subsequently managed to start the engine and the oil is still staying where it is supposed to be. 🤞🏻
