Plans changed to make the garage bigger, currently sitting at Municipality for approval. Once approved then the building will commence.
For now I am just collecting parts for the turbo build.
I have swapped out the oil cooler I was going to use for a Setrab unit so I can change the fittings, now going to run M12 AN style fittings with s/s braided lines.
I did swap in a e46 320d clutch and flywheel for the 6spd though, its way heavier than my old setup 11.6kg vs 19.8kg. Its soft and easy to press now since I installed the M3 clutch master and slave cylinder with a braided line.
I would like to see if the 330i 6spd clutch/flywheel setup is alot less than the diesel one, if not then a custom alu flywheel.
