Hi guys
What's the difference between the OEM Bosch O2 sensors from the $tealer$hip which cost R3800 each and the Bosch universal ones that cost about R800??
These are for a s50b32 M Coupe.
This is the part I find strange when I look them up on RealOem, does this mean the O2 sensors for this car are only specific to this car?
11781406621: Sensor 1 is compatible with the following vehicles:
Part 11781406621 (OXYGEN SENSOR) was found on the following vehicles:
Z3 Z3 M Coupe, S50, Europe (CM91) : Lambda Probe Fixings
Z3 Z3 M Coupe, S50, Europe, RHD (CM92) : Lambda Probe Fixings
Z3 Z3 M Roadster, S50, Europe (CK91) : Lambda Probe Fixings
Z3 Z3 M Roadster, S50, Europe, RHD (CK92) : Lambda Probe Fixings
Z3 Z3 M Coupe, S50, Europe (CM91) : CATALYST/LAMBDA PROBE
Z3 Z3 M Coupe, S50, Europe, RHD (CM92) : CATALYST/LAMBDA PROBE
Z3 Z3 M Roadster, S50, Europe (CK91) : CATALYST/LAMBDA PROBE
Z3 Z3 M Roadster, S50, Europe, RHD (CK92) : CATALYST/LAMBDA PROBE
11781406622: Sensor 2 is compatible with the following vehicles:
Part 11781406622 (OXYGEN SENSOR) was found on the following vehicles:
E46 M3 Convertible, S54, Europe (BR91) : Lambda Probe Fixings
E46 M3 Convertible, S54, Europe, RHD (BR92) : Lambda Probe Fixings
E46 M3 Coupe, S54, Europe (BL91) : Lambda Probe Fixings
E46 M3 Coupe, S54, Europe, RHD (BL92) : Lambda Probe Fixings
E46 M3 CSL Coupe, S54, Europe (BL95) : Lambda Probe Fixings
E46 M3 CSL Coupe, S54, Europe, RHD (BL96) : Lambda Probe Fixings
Z3 Z3 M Coupe, S54, Europe (CN91) : Lambda Probe Fixings
Z3 Z3 M Coupe, S54, Europe, RHD (CN92) : Lambda Probe Fixings
Z3 Z3 M Roadster, S54, Europe (CL91) : Lambda Probe Fixings
Z3 Z3 M Roadster, S54, Europe, RHD (CL92) : Lambda Probe Fixings
