O2 sensor
G
GeminiMike
I heard via via someone said something about a replacement O2 sensor for the E46 that is kind of like a dud sensor that's tricks the motor into thinking its still there however this sensor is much better than the original giving better fuel consumption and engine power.
Yulesen said he thinks I am talking about a Mini CAT/CAT fooler. You put this on after doing a decat (Your Post CAT O2 sensor is plugged into this CAT fooler) so the engine light doesn't trigger and the ecu is fooled in thinking the CAT is still there and a result is slightly less consumption after Decat.
Has anyone heard of this before and if so where can I get one?
msm
I recall seeing a DIY a while ago, but can't remember where ....
Basically from what I remember, some guys do a "spark plug" mod where they position the sensor a few cm's back so it does not get a proper reading of the gas flow.
Look here:
Spark Plug Defouler for O2 sensor
