NOISE ON START UP
nawtiboy
hey guys
started the ci this morning
sounded like a loose belt noise
i checked the bely -seems tight
also i noticed the power steering cap has a sort of sweat around it-fluid is okay
any clues ?
to be honest -i've heard the sound before but it usually went away after 2-3 seconds -now it seems to stay for a few minutes and once hot -it's gone
water pump/power steering pump ?:mmm:
speeddemon
had same problem on mine...turned out to be the aircon belt that jumped off a touch....all i did was:
1 switch off the car
2 put it in first gear but leave handbrake off
3 jerk car forward by pushing and Wallaaa!!!! it jump back on and noise is gone...
Hope it works for you too:)
nawtiboy
cool :thumbsup:
although the steering is not hard and everything seems normal -i tried lock to lock- it's fine
like a screeching sound -exactly when a belt is loose
i tried switching the a/con on while it made the noise -no change
will see what's going on and check if the belts are sitting ok
:thumbsup:
called Canadian :thinker:
chap reckons there are 2 types
long and flat/short
2950 for the short fitted -just in case it is the pump
have to check which one i have
:thumbsup:
Gizmo
Banned
Deano is having a similar issue, I will be replacing the idler pulley and the tensioner pulley tomorrow. Will let you know how much it costs.
I had the same issue with my 330i about 6months ago, while I was at it I replaced the water pump along with the 2 pulleys and a new belt. Now its whisper quiet and I have peace-of-mind as far as the water pump goes, good thing I replaced it when I did as the bearings were SHOT!!!!
zaleonardz
Aircon test you have done.
Altenator can be tested that if you have the noise, and you turn on the lights, it should get worse.
Good luck dude.
Gizmo, price me a waterpump for my M60 please, i better get that done as well.
Gizmo
Banned
Good luck dude.
R1500 for the M60.
zaleonardz
Shot Gizmo.
Will let you know, I am looking for a thermostat as well, just in case.
My car runs cool, and obviously cooler with the manual then with the auto as the water cooler of the auto is cut out, sits nicely in the middle, but as you say, you cannot be sure. I do have a bit of a water leak though, so i guess some work to be done there.
