Good morning. Can anyone point me in the direction to solving a low power issue with the car. It was off the road for 4 months and then had a new solid flywheel and clutch conversion kit installed. When i got the car back, there was a distinct stuttering/jerkiness at low rpm and no acceleration. Once you got over 2500rpm it took off. Car also loses power going uphill. I cleaned the MAF sensor which removed the jerkiness but still have the low power issue. I used a basic code reader which threw up a P0402 code - Exhaust Gas Recirculation Flow Excessive Detected. I've cleaned the EGR and the problem is still there.
I've got 420,000kms on the motor and while it uses a bit of oil it's still runs well and didn't have this issue before the clutch job. Any advice or direction on where to look would be grateful. Thanks.
