thanks guys
im so glad the car is running properly again:=):
its also given me some inspiration to start fixing all the other small issues with the car i could find,
you realize what a difference fixing a small problem can make and it gets you amped to carry that momentum forward:thumbs:
just a couple side notes on my previous post:
the reason i went walbro pump and not a bosch replacement or pierburg oem pump, or any other for that matter is i have had them in two other cars with no issues, and dealer quote for R4500 +- for a fuel pump and a walbro costs R1200 +- and is a trusted pump...
also something to try that i did if experiencing the before mentioned no start issue is putting petrol in the tank, 1st - it mite be empty, 2nd can save you money instead of getting car diagnosed or towed etc, 3rd - have heard stories of some e39's refusing to start and will only start with on occasions 1/4 tank, 1/2 tank, sometimes even more needed
not to sure what causes this if someone could enlighten?
also a quick tip to see/hear if your fuel pump is working on your e39 is remove the bottom half (not backrest) of the rear seats, simple, and listen to hear if the pump primes and runs (humming electric motor sound) when turning the ignition
dealer quote for new power steering pump (brand - Luk) R4700 +-
been looking around and most pumps new cost R4000+, rebuilt R2500+-, and second hand scrap yards etc R750+ to about R2000,
so wanting a new one im looking here as it seems it will be the best deal taking everything into consideration, quality of pump vs price vs etc
best option just do it right and get a new 1 imo
http://www.eeuroparts.com/Cart/Cart...Code=32411141570&partName=Power+Steering+Pump
should work out to about R3500 +-
or here
http://www.ecstuning.com/BMW-E39-540i-M62_4.4L/Steering/Pump/ES2581687/Cart/
