firaz said:Hi,
Check your tyre pressures, might be as simple as that.
Regards.
Sent from my HTC One mini 2 using Tapatalk
Ralf* said:Maybe also check your tyres pressures, it could be that they overinflated your new tyres, thus stiffer and smaller footprint on the road.
shailesh said:....Michelin PSS and replaced it with Toyo proxes...
shailesh said:do the new tires still need to wear in ??
Bavs108 said:Did you have wheel alignment done when you changed your tyres? I would think if the car feels "loose" it's because your alignment is off. I usually have this problem when my camber isn't set correctly.
shailesh said:Bavs108 said:Did you have wheel alignment done when you changed your tyres? I would think if the car feels "loose" it's because your alignment is off. I usually have this problem when my camber isn't set correctly.
yes i had wheel alignment done and the wheels fitted here at TWT jhb.
they say they do all the cars for BMW mooi
shailesh said:who is the best to do wheel alignment at?
pimpassdaddy said:Yup... Budget tyres dude. Simple as that!!!
I've driven a car with them on... Found them shocking!!!! Toyo is decent though, better than that Wanli or Silverstone crap though.
You definitely can't compare them to Michelins. With tyres, you get what you pay for... Well most things really.
