Need help e34 540i
Mafalie
Hi gents. My car all of a sudden started leaking water when its hot. It leaks from underneath somewhere by the gearbox. I have checked all pipes and they seem fine. What could it be?
The water also bubbles when the expansiin tank is open.
Ocky
Where are you based buddy?
Would be easier to diagnose in person
Mafalie
I am in Roodepoort buddy.
Peter@AEW
Likely that a heater hose has ruptured.
Have a look at the back of the motor after removing the sound deadening cover.
Blue Shirt
It could also be the dreaded valley pan leak, you typically see the coolant leaking down the back of the engine over the bellhousing.
JayDrft
Im with Peter on this one - My e34 was getting hoter than usual, and one day after a long drive - parked the car, and opened the bonnet...only to hear a hissing noise coming from a tiny leak on one of the heater pipes entering the firewall, I cleaned, refitted and tightened that sucker up,and never had an issue since.
Hopefully it helps...is it a slow or fast leak?
Solo Man
It could be aircon water condensation as that drain pipe is routed by the gearbox. Just my 2c's, seeing that summer is finally here and we are using our aircons again!
