Hubblyking said:NeW would be agents used you can try md house.
What's your mileage.
Did you check plugs.
What fuel and map are you running.
Sent from my SM-G928F using Tapatalk
spikey said:Hubblyking said:NeW would be agents used you can try md house.
Mileage is 115 000km
Plugs were changed about 5000km, too soon to need a regap?
Using 95 pump fuel on MHD Stage 2 95 RON
spikey said:Added octane booster, will see if it helps, also realized they put N54 triple contact plugs instead of the single contact N55 plugs. Going to change plugs first to see if it makes a difference.
Sent from my E5823 using Tapatalk
I replaced coils and plugs.DannyBoyOPC said:you can also get new coils from Goldwagen if i remember correctly
akash said:What do your IAT look like
