N54 Water Pump Change
KrS24
Hi guys
At what mileage did you change your water pump?
Did anyone here purchase those water pumps on gumtree for R4k-R5k?
My thermostat packed up and I am contemplating changing both in one go.
Kish2604
Administrator
My water pump developed a fault at 115k km...the error if I remember correctly was a speed deviation fault.
Replaced both pump and thermo at the same time.
cOlDFuSiOn
Makes sense to do both, but rather not with a part off Gumtree :fencelook:
IIRC correctly a buddy of mine's failed at similar mileage the 11x k kms mark ..
Woodies
Mine went on 80,000kms. Engine overheating light came on yellow, then red and power was reduce massively and had to pull over. You could hear the fan working super hard. Covered by MP (around R7000 it would have cost), then 3 weeks later the fan started making weird sounds. R10k fan replaced under MP.
KrS24
Goldwagen Centurion. 7K for the pump and thermostat. Should be just as good as OEM. My pump was still running strong. I just did not want to take a chance with my setup.
335i MTX
I had the same thing happen (N55) at 85000kms. Fan hasn't failed yet though. 14000kms still left on MP.
