n54 wanted to test open flash by vishnu tuning
Javbrat-wp
hi guys ,
im looking for a n54 to test , i want to try the vishnu tuning flash tablet software. the numbers are great and the tune is also affordable . if anyone is keen please let me know)) im prepared to go half so if anyone is keen let me know))
boost3d
May I ask why you wouldn't consider the BimmerBoost/Bms backend flash? Other then the cost of a BT cable, their back end flashes are free and Terry updates each back end flash every time he releases a new Hex file to go with the Jb4 N54 Iso piggyback.
hoosain
+1
i did a backend flash on my car using the BT cable and all i can say is WOW its a different car
David1
Hoosain, please can you elaborate in what way it changed? Did you have a jb4 before and now you using the bms backend flash?
Thanks :thumbs:
hoosain
Thanks :thumbs:
yes i had jb g5 iso before
i did the bms backend pump flash
the car targets between 15-16psi on pump fuel and the car targets the boost much earlier in the rev range
car feels like shes on nitrous
i then mixed 30% ethanol and the car targets 17-19psi
previously with jb alone in 4th gear the car used to drop boost by at least 2psi its now holding boost without a drop
did some logs and everything looks good
David1
George Smooth said:
David1 said:
Thanks :thumbs: I'll go that route soon
I got a cable you can use.:thumbs:
Thanks very much for the offer George!
I am going to buy a cable soon as I still have motorplan so that I can easily remove the tune and also for updates
Thanks again :thumbs:
Javbrat-wp
mmm i work with rob from vishnu, we will do logs on the car and from the logs he will develop a file for the car.. not off the shelf files .. so yea if that answers your question
hoosain said:
Thanks :thumbs:
this is awesome hoosain.. whats the timing sitting at and boost at shift?
