duckittmail
Hi there
I have a E46 318i 2004 (N46B20), a couple of months ago the car lost a major amount of low down power at pull aways it sort of goes and then hesitates badly and then once above +-2000rpm it pulls fine. Thats the first problem. And now if i accelerate hard or play with the throttle the eml light comes on and the car goes into limp mode, if i turn the engine off and back on the eml goes away and its fine as long as i accelerate gently.
What i think it could be is the vvt servo motors worm gear that is worn, causing the issue.
Any suggestions on what it might be?
Thanks:rollsmile:
Thanks:rollsmile:
