nathwright05
Hi, my first post on here so here goes.
i own a e46 e316i UK with a N42 engine.
i have a blue smoke on idle issue accompanied with what i suspect is a oil leak as i am using around 1ltr every 300 miles
i have changed valve cover gasket which had failed leaking oil on to heat shield during this process i found one of the bolts at the back of the bulk head. was not really biting at all when tightening. gggrrrrrrr
i have used gasket sealant to help and i cant see any more oil on heat sheild so i think it might have done the job, but then the smell was back. so i did a DIY on the vacuum pump o rings. this has kind of worked but every now and then i get that smell, usually under harsh breaking.
now i have also changed the cvv and intake gaskets and the one that go under valve cover for sparkys.
the crappy pipe over the intake had collapsed and has been replaced but i still get smoke on idle. i have done the bag trick over the oil filler and made sure there is a slight pull down. my local mec is sure its not my valve stem seals and claims to never needed to change this on my type of car. if i can i like to DIY and sort these problems out so if anyone out there has some positive and other than take it to a main dealer. please comment.
2 problems
1 oil burning smell
2 blue smoke
thanks in advance.
2 problems
1 oil burning smell
2 blue smoke
thanks in advance.
