Philip Foglar
Okay, so just over a month since I bought this car and still very happy with the purchase, there are still loads of things that I want to attend to. Will post all progress in this thread.
Within the first week of getting the car I had the two front lower control arm bushes replaced and all other bushes checked seemed fine. Alignment was done too.
Had a set of 17" wheels fitted (well, returned since the one was supplied with a very bad buckle), so running on the original 16" wheels until I get another set of 17" wheels - new Hankook Ventus V12 EVO's to be fitted again...
Earlier this week noticed that the right headlight was out, replaced both front headlight bulbs with the Osram Night Breakers - definitely brighter and whiter than the original Philips bulbs.
This evening replaced the power steering fluid - was a bit low and quite dirty. Also hoping that the power steering will now be quieter, but have a feeling that I will still need to just replace the power steering pump... Will update!
Still to do:
9k km till next service, but will have the oil and filter changed in due course anyway.
I want to replace the various cooling system items, expansion tank, water pump etc.
Handbrake needs to be adjusted or relined - seems a bit weak...
Both front window mechanisms need to be replaced, the rear window mechanisms seem to be fine though.
Clutch shudders a bit when cold, so if this starts to get worse will have to think about having this done most likely.
Brakes are still fine, but at some point will replace disks and pads.
Shocks are fine, but need to have them properly tested and replaced if necessary.
Want to have all bushes checked again - second opinion to find the cause of the "thud" sound between some gear changes or when engaging a gear at standstill.
So still very much a work in progress, but worth it! Much better than some silly econobox!!! :thumbsup:
Anything else I should be doing?
Philip
Still to do:
Philip
