Porra46
And so I attempted the DIY fitment...
From some guides across the net, I thought it wouldn't be so bad.
The hardest part is getting thebadge off. You have to lock the car and lift the badge so it doesn't open the boot.
Then a very very very tiny flat screwdriver is pressed under the chrome emblem and wedged slowly until you hear a pop. The bottom section lifts up and I slowly wedge it open some more until I can get an old credit card or a small plastic ruler in there. I continue to work the plastic ruler until the whole badge pops off.
You are then left with a dirty section that must be properly cleaned before sticking on the Klii inlay.
Some thinners and a clean cloth did the trick.
And then I stuck the candy white inlay as carefully as possible!
The badge just presses and clicks back in. Definitely way easier to put back than take off.
And the result...
And the result...
