My Turn for Advice Needed
D
Dippies
Ok Guys i noticed something yesterday i thought i was paranoid and this evening when i pulled into the garage i could hear the noise Clearly.
The Problem
When the car is in neutral and you press in the Clutch pedal Just befor you get to the bottom of the Floorboard (Clutch Fully pressed in) there is a awkward sound from the engine bay.
Im thinking the following Release bearing or Clutch Plate or Pressure Plate.
There is no rattle in the Pedal what so ever and gear shifts is as Smooth as always. No Error Codes received
What do you guys think.
Its a worrying Noise and Clearly not the same as when i bought it.
and most of All Estimated Cost of release bearing and Clutch Pressure plate
Car is a 2006/7 320D
Any advice would be appreciated
Massi
Loose flywheel...
Releaser Bearing.........
Thrust washer.........
Crankshaft rear bolt loose........
:fencelook:
Flash-Gordon
I've got no idea, some people claim to have been driving with that noise as long as they can remember :dunno:
Maybe Gizmo could give you some advice? :fencelook:
D
Dippies
so it mite be the Dual mass Flywheel :fencelook:
Any ideas for cost to repair
D
Dippies
only way to get to it is to pull the gearbox right :fencelook:
cOlDFuSiOn
My E90 320i made a noise like that. BMW replaced the dual mass flywheel, pressure plate and a new clutch under MP @ 90k kms. Car was killing clutches though. :thumbdo:
cOlDFuSiOn
Dippies said:
car is not under motorplan :fencelook:
The clutch was slipping though and the car was jerking very badly to the point where it was undrivable.. I had to sell the E90 as the BMW techs admitted there was clutch issues on the 320i manual - it overheats in traffic that's the end of it I was told..
Best of luck man, I would still rather fork out the cash amd drive a BMW anyday regardless!
S
SP33DYV
Release bearing. Not a biggie.
Sent on the run from my iPhone using Tapatalk 2
D
Dippies
My initial thought but after seeing that video by Flash my suspicion is the duel Mass Fly wheel
S
SP33DYV
That sounds like the release bearing if you ask me. Mine used to sound exactly the same before I had the clutch plate, pressure plate and release bearing replaced.
