My refurbed 19inch rims finished!
EmD20v
This colour is difficult to pic up on the camera especially when its on the car........it look lovely in the direct light though
Razz
Please send me your contact details, have a buddy needing a set refurbed
supertramp
Hi his name is Ryan number 076 280 2921 business is called RRR-stylin check out his Facebook page and he is on our Forum. :thumbs:
Kish2604
Administrator
supertramp said:
Yup however that will be covered in break dust after 2 weeks so doesn't really make sense in spraying the inside of the rims :fencelook:
If it's a half spray job on the outside of the rim let alone the inside then that can't be called refurbished.. It may sound harsh but I am just calling it like it is...
TurboLlew
I hope you got that in writing, since the right size for the back is 275/40/19 which has an identical diameter and almost identical (2mm) circumference to the front. The tyre you have (45/19) results in a 27mm difference in diameter and 85mm circumference difference front to rear within the set. With stories of how finicky the AWD system is on these I would double check.
On some other AWD platforms, having slightly different tread depths is enough to cause issues...
tman
Nee man. Call me OCD, I won't be able to live with that.
Sent on the move using Tapatalk
supertramp
Hi bud, apologies you are 100% correct the tyres they recommended and have been fitted by SMG are 245/45/R19 fronts and 275/40/R19 rear :thumbs:
