Okay so bar having to cope with about 13.5l/100km the car performs pretty good as a daily.
Four things do require a bit of attention,
Firstly, the car is very optimistic about the outside temperature, I have read a bit and know the sensor is fairly cheap but also read about calibrating it? Any body with some info on that?
Secondly the CD changer is a bit suspect. I thought it was gone as it didn't eject the cartridge but a light pat on the back loosened it and it plays 3 for the 6 cd's now. So I will just clean that.
Thirdly I need to replace number 4 cylinder coil as it missed a few times and diagnostics showed it at number 4.
Then the big one. I had it at two very good guys already and both confirmed that there is a noisy lifter as I suspected. Both quoted me the same amount more or less to replace all the lifters.
Now my question, is there someone that will be able to find and replace just the one noisy lifter, do I go for broke and have all of then replaced or do I risk just fitting a redone head and hope all the lifters on that is fine? Maybe try thicker oil? I don't know what route to take . . .
