My M135i Build
Donnie Darko
Sherwin@xcede said:
donnie darko said:
c0mrade said:
hi bud when is she going to the dyno ? would like to know what sort of gains
the dp gave you :thumbs:
When i get time bud. Prob around 10wkw.
Problem is a did not dyno just JB so wont know exact gains.
Put it in map 0 to see the gain of the DP.
Never thought of that Sherwin :coolShake:
c0mrade said:
gloach335 said:
ACS downpipe Bro
that explains you leaving it in
but it's not the same as his DP your's still has cell's in it, his is completely decat
:thumbs:
:cartel:
Donnie Darko
Been looking for an intake for the M135i for about 2 weeks. Looked at BMS intakes but no stock available.
Did some more research and found Injen make intakes for the M135i.
Managed to source one that is in good condition. :coolShake:
I also got my JB4 cable so i can play around with stuff on the laptop :cartel:
Collected both last night :rollsmile:
Pic of intake:
Pic of how it will look fitted:
Quick///M
donnie darko said:
Watched some youtube clips of this intake. Makes nice sounds :cartel:
Awesome intake! Post links for the intake videos. Keen to see what your car will dyno with all these mods :)
Donnie Darko
Me too bud!!!!
I have a number in my head with just pump fuel so lets see :cartel:
A small clip of intake:
c0mrade
hey bud that looks great ! but won't the car get heat soak quicker ? i was talking to someone and he said just using a better quality air filter would be better ,he says car gains sound but not performance with intake :coolShake:
Nikhil
Awesome stuff! Look into getting your boost pipes and intake pipes ceramic coated inside and out :rollsmile:
Donnie Darko
I dont race so i im not worried about heat soak. Intakes allow more airflow irrespective, so more air equal gain. Might not be much but the sound factor for me is tops. Anyway the ram tube from the front of the car still get used in this setup. These guys do testing so they wouldn't sell something that does not work :coolShake: At a later stage i could do heat powdercoating for the heat issue also.
Donnie Darko
BMS, Injen, AFE etc... all give about a min of 10hp gain. Even if its half that its still a gain :coolShake:
If i find it does not work well enough il get the AFE intake(cr@p expensive but a sealed intake). BMS is on PAR with what i got now from what i have read.
gloach335 said:
If it sounds good that's perfect. Loud and proud
You dont suffer heat soak on your BMS do you G?
Injen sits slightly further away from the motor then the BMS as you to remove the whole airbox.
Donnie Darko
c0mrade said:
i'm all for this and just asking because i'm going down same route:thumbs:
I tell you what bud, When im done please come meet me and ill take you for a spin and you can tell me if it was worth it :rollsmile:
