zippy320
Hi Guys
Sad Sad sad news
I have an E46 318i Automatic with N42 engine.
Will try and explain the situation to you as best I can.
The vehicle turns over , as normal but wont start ,
I had the AA come over , the guy checked all the fuses and battery and concluded that its the fuel pump at fault.
When turning the key into position 2 I don't hear a buzz, I checked all fuses and non seem to be at fault. Generally from experience with the E30 not starting , if the fuel pump was pumping I would have a strong fuel smell near the engine, in this case there is non, which leads me to believe that its not pumping or getting power.
I attached one of those 12v light testing pens to the two contacts on the fuel pump fuse (the one in the glove box) and it does not light up. Should it light up?
I checked the fuse No.3 in the engine compartment and that also seems fine.
How do I test if its getting power?
How do I test the pump by attaching 12v to it to see if it would spin? (which pins do I use?)
How do I attach my 12v light to the wiring to see if it would light up?
How do I test the relay? The one in the glove box? Can I use my 12v light?
I have the car battery on charge now , as it did loose power while testing . Though at this point, im not even sure where to start.
Could low power from the battery also cause this?
Im not sure if this is related , but for the past week or two , I have been having issues with my fuel gauge giving incorrect readings, Iv been keeping the tank topped up at around half all this while but once it reaches the 1/4 points it cuts out.
Thanks for all your assistance , This is so depressing
Sad Sad sad news
