guess they will have to run compression, injector, fuel pump tests... cant they log data to see if its loosing boost or the afr is not withing spec...
moranor@axis said:guess they will have to run compression, injector, fuel pump tests... cant they log data to see if its loosing boost or the afr is not withing spec...
Jacques24 said:I dont agree with their view: Can anyone with a stock 335 confirm if the first minute or so has an uneven/slight misfire on a cold startup? They claim it's the CATS warming up, this is total BS (my car is doing this for only 2 weeks now).
I agree: When I start my car (cold), the one exhaust seems to be closed and after a minute or so the car idles differently and the second pipe starts pushing out steam. It's always done this, but now with a rough idle/misfire untill the motor picks up some temp
Twinz said:Jacques24 said:I dont agree with their view: Can anyone with a stock 335 confirm if the first minute or so has an uneven/slight misfire on a cold startup? They claim it's the CATS warming up, this is total BS (my car is doing this for only 2 weeks now).
HOWEVER: All turbo cars on start up or when at idle will sometimes have the sensations of "misfiring". Its a difficult thing to describe: when you sitting inside the cabin you will "feel" it. But when you outside the car listening to the exhaust you wont hear it. Its a feeling/sensation. Its like a tubulence effect going through the exhaust. But a real misfire you will (hear) when outside listening to the exhaust.
Interestingly enough I have not felt this "misfire" sensation with a diesel car. But in a GTR & Scooby definitely. You just know you starting up a turbo fed car.:thumbs:
Fayz said:Was your car smoking on startup,giving off a heavy fuel smell?
Jacques24 said:Fayz said:Was your car smoking on startup,giving off a heavy fuel smell?
No nothing, but I can hear the misfire when outside of the car
Twinz said:Smoking and fuel smell...what the hell. Keep us updated Fayz.
Fayz said:Jacques24 said:Fayz said:Was your car smoking on startup,giving off a heavy fuel smell?
I think that's normal,mine also sounded like there was a misfire and then it would settle after a few minutes but the symptoms I had now was quite bad with smoking and a heavy fuel smell.My car was definitely not firing on all cylinders.I haven't received my car back yet,the service advisor said maybe this afternoon.Will let you know of the outcome.
Jacques24 said:So BMW phoned me yesterday, they are replacing 4 injectors, will report back next week :thumbs:
