My 330D tractor
Gizmo
Banned
Thanks for the compliments guys. She really is a great driving vehicle and that colour is awesome in person, pics don't do it justice.
Really making me consider an e90 LCI 330d wagon as my next build. :fencelook:
KidB
Updates after a looong time,
De-dpf + EGR delete via software [Done at 140'504kms]
Freeflow rear silencer + better tailpipes [Done - MTA4MDA=]
Steering wheel trim refurb [Done]
Mobility Kit [Done - MTY1MA==]
Shield Diesel Injector Cleaner [Done at 140'598kms]
VPS (Full Bonnet, Full Fenders, Full Front Bumper, Headlights + Fogs + Door sill + Boot sill [Done - MTAyNTA=]
Detailing [Done]
Passenger arm rest needs replacing [Done - thanks to Adi for his excellent hot glue gun tip in the DIY section]
Bluetooth retrofit (The car has bluetooth preparation) [Done - thanks to Gert for his amazing knowledge on everything! - NTAw]
Swag OEM replacement Front Discs + Textar OEM replacement Front pads + OEM pad sensor [Done at 142'990kms] 15/10/2016]
Axis brake guide bushings Front [Done on 08/10/2016]
AC fan control buttons are worn [Done]
The vent tabs are broken off so they need replacing [Fitted 06/12/2016]
Rear wheel bearings [Completed 145'988kms 13/01/2017 - Ross Duncan - NDk0OQ==]
Crank dampener pulley needs replacing [hasn't failed yet - failed at 146'900kms 25/02/2017 - Ross Duncan - OTgwMA==]
Oil change + Air filter [Done 146'900kms 01/03/2017 - Ross Duncan MjcxMA==]
Boot Mat installed [Done 22/03/2017 - Afriboot - MTM1MA==]
Diff repair complete (was humming) [Done 149'962kms 19/06/2017 - Ross Duncan - Nzc1NA==]
Gearbox service [Done 150'672kms 05/07/2017 - ZF - MzkyMQ==]
Rear Discs + Rear pads + brake pad sensors [Done 159'128kms 27/12/2017]
Slight vibration which is worse under braking (Resolved - Turns out this was caused by one of the rear disks being warped and chipped)
Sump replacement (after stripped sump lug) [Done 158'000kms 28/01/2018 - Gizmo - Sump (ODMyNQ==) Tot (MTY4NjI=)]
Oil leak after putting the car on the ramps at the gearbox service (The stripped sump plug caused this)
Oil Filter + TT4100 [Done 158'000kms 28/01/2018 - Gizmo]
Oil Filter + TT4100, Sump plug Torqued to 18Nm [Done 170'956kms 12/010/2018 - Kid]
Ait Filter [Done 170'956kms 12/010/2018 - Kid]
Coolant replace
Fuel filter replace
Brake Fluid Flush
335i intercooler upgrade
Axis brake guide bushings Rear
Radio LCD (dead pixels)
The leather on the driver side bolster is worn and needs replacing
The leather on the drivers seat needs to be tightened
Front floor mats are worn and need refurbishment
Sunroof maintenance
Rear windscreen rubber
Greasing doors
Bonnet heat shield needs replacing
CF mirror covers
CF boot spoiler
Wheels refurbishment
Rim skins
Upgrade the sound
Driver seat bolster deflates
Super dirty air filter compared to new one, should have changed that way sooner
