My 135 build. Update on PG2.
bmsportzn135i
Ok so its been since forever since i last updated this thread, i thought i might as well add to it.
So as most of you will already know, i installed the RB's
Below are what the stock snails look like.
These are the upgraded snails.
So with the Meth up and running and the new turbos working like a dream, i got in contact with a guy in the states, AKA wedge.
So with his 15deg map loaded on the car, i went off for a dyno day and this is what i ended up with.
Whats next you may ask...
Definetly an racing clutch, as the stock one really cant handle these power levels.
Then when i can finally get my hands on a 2nd hand 135 diff, i'll me fitting an LSD to it.
:thumbs:
Prev
Administrator
Well done JP :bravo: can't wait for you to achieve those low 11's
Twinz
Forum - Support
Good update. The car is strong. I saw the log of that run which you posted on another forum and its very impressive.
Twinz
Forum - Support
JP you running the 27.13 firmware? To
prevent the high boost + high timing + lean AFRs from going out of whack. This particular firmware is also safer with an agressive lean AFR as with the Wedge flashes. I think it backs down between 4 - 10psi when things go heywire.
The 27.12 firmware does not have this safety unless you ignore the Flash (OEM) boost which in your case is pretty high.
Look forward to your thoughts. :thumbs:
Johnny135i
Dude well done on this build!!:thumbs:
It's an inspiration to the rest of us mortals running <300kw x35's!!
Thanks for keeping us updated.
Truly impressive figures:bravo: keep it up!
bmsportzn135i
Dean ///M said:
After July we unleash the horses and run low 11's:thumbs:
Yip. i cant wait.
Honeymoon and then new hardcore clutch setup.
Time to start smoking the comp.
:thumbs:
It's an inspiration to the rest of us mortals running >300kw x35's!!
Thank you.
Its achievable for all of us, just be patient and make sure you are on friendly terms with your bank manager.
Thanks Charles.
Yes, Just the other day i actually updated to 27.13.
I've also changed the wedge map from the 15Deg timing to the 13.5Deg timing also for safety.
Basically i'm detuning it a little bit. Rather safe than sorry.
At the end of the day, its not what your car makes on the dyno, but rather how it performs on the road.
I will also be trying out the option 4-2 on the in dash to see if the linear throttle will help in bringing the 60ft times down some.
But so far, its an absolute joy to drive.
Just the other day i got to play around with a Ferrari 458.:joy:
Tareeq
:praise: this is amazing :bravo:
Very Well Done on this Build it's what dreams are made of :inlove:
$nivz330d$
well done bud !!!!!!!!!:joy:
amazing power figures..... dam KO4 whaaaaaaaaaaaaaaaaaaaaaat!!!!!!!!!!!!!!:roflol:
:thumbs:
