andrewbuch
Wish I had gone to the Post office this week to collect the jack pad
got a puncture and had to jack up now with out a jack pad, the small trolley jack I got doesnt sit nice on the jack point so makes for risky jacking
Twinz said:The following performance products arrived and we had an opportunity to test them all. These items are relatively small and not too expensive. Let us know if you are interested and we will pop these in our next big order for you; and in that way bring the freight saving to you. However, we prefer to provide pricing via PM or email because it is dependant on exchange fluctuations.
A. BMS CATCH CAN
Keep Oil Out of your BMW 135 335 Air Intake System. It's no secret that the BMW N54 motor suffers from serious oil control problems causing oil to blow through and coat the intercooler and charge piping, gunking up intake valves and the VANOS system, lowering the effective octane, and generally degrading engine performance. The higher your boost levels the more apparent these problems become.
B. SPARK PLUG SOCKET TOOL (N54 & N52 models)
The socket fits like a glove. It also includes an integrated magnet to secure the plugs while raising and lowering them in the long bores.
C. JACK PADS
No more broken factory jack points or damage to your rocker panel or vehicle undercarriage. Lift your BMW correctly, securely and perfectly aligned every time.
D. SHORT THROW CLUTCH STOP
Fits all 1982 - 2012 BMW manual transmission.
Faster and smoother shifts with no other modification This adjustable clutch stop allows faster and smoother shifts by removing the dead space between your clutch pedal and the floor.
LOOK HERE: CLUTCH STOP DISCUSSION
E. PROTECTIVE WHEEL SAVER SOCKET
Equipped with a synthetic polymer coating and insert the BMW protective wheel saver socket glides around your rim as you unscrew and tighten your lugs leaving no scratches or signs of wear.
F. PLUG & PLAY PERFORMANCE CHIP FOR THE BMW N51/N52/N53
It features easy installation and removal. Throttle pedal remapping for snappier response and gas pedal switching between 7 performance maps. We have tested this on a 130 with very good results.
G. PLUG & PLAY PERFORMANCE CHIP FOR THE BMW N55 (Stage 2)
Finally available for RHD vehicles and shipping with JB4 featuring 5x the processing power, 2x the memory, more robust signal conditioning, and integrated CANbus. Features include code reading/deleting, optional in dash boost, timing, air/fuel, shift light, and IAT gauges, autotuning, a buttery smooth new CANbus based integrated boost control system, map switching on the fly via steering wheel controls, built in downpipe fix, hot/cold oil temperature protection, progressive methanol integration, water pump remapping, gear dependent boost control/traction assist, and much more to come...with free firmware updates.
H. BMS DUAL CONE FILTERS
Exclusively for the 2007-2010 BMW 135, 335, 535i and Z4 N54 Twin Turbo. Featuring quality S&B inverted cone filters the dual cone intake offers the highest possible flow in an attractive and easy to install package. Not to mention intoxicating sound.
MORE Products & reviews to follow in the coming week.
:ty::ty:
A. BMS CATCH CAN
Keep Oil Out of your 135 335 Air Intake System. It's no secret that the N54 motor suffers from serious oil control problems causing oil to blow through and coat the intercooler and charge piping, gunking up intake valves and the VANOS system, lowering the effective octane, and generally degrading engine performance. The higher your boost levels the more apparent these problems become.
C. JACK PADS
No more broken factory jack points or damage to your rocker panel or vehicle undercarriage. Lift your car correctly, securely and perfectly aligned every time.
Fits all 1982 - 2012 models with manual transmission.
Equipped with a synthetic polymer coating and insert the protective wheel saver socket glides around your rim as you unscrew and tighten your lugs leaving no scratches or signs of wear.
G. PLUG & PLAY PERFORMANCE CHIP FOR THE N55 (Stage 2)
Exclusively for the 2007-2010 135, 335, 535i and Z4 N54 Twin Turbo. Featuring quality S&B inverted cone filters the dual cone intake offers the highest possible flow in an attractive and easy to install package. Not to mention intoxicating sound.
:ty::ty:
