Shaunreddy
Hi BM fanatics,
I need some advice with this! 330i E46
Firstly the car picked up a misfire.
So I got a buddy to plug in his diagnostics to see.
The error was Misfire on Nr 6…… We cleared it several times but it still persists.
Action taken after that
1. Changed coil & spark plug – No change
2. took car for compression test – All bores are 100%
3. Looked if there was spark created at plug – all fine.
I have run out of ideas on what to check. There are no other errors on the diagnostics.
Can some one point me n the right direction, or may have had this same problem.
Thank you
Shaun
Thank you
Shaun
