Hi Guys,
After installing catless downpipes on my N54 335i, i have been getting the following codes ever since
2c77 Lambda probe behind catalytic converter, signal
2c78 Lambda probe behind catalytic converter 2, signal
Im not getting any CEL or anything catastrophic wrong with the car, but im concerned these codes could be interfering with the cars AFR and fuel consumption.
Has anyone used mini cat foolers (see image) to fix this and if so do they actually work. Also, apart from this and using the JB4 autoclear function, what else can i try to clear these codes up permanently.?
D
D
