MHD QUESTION
BMW N54 –
DCI , EXHAUST SYSTEM(OEM DOWNPIPES) –CHARGE PIPE
What will be the recommend stage to install on the above application ?
I know the most safest (FOR ABOVE APPLICATION )is stage 1 , can a person go stage 1+ with oem cooler ?
Can a person go stage 2 or stage 2+ ( I have seen guys run this on oem cars and no issues) provided you are not tracking or racing car continuously as heat soak then kicks in .
On both stages what sort of power and torque increases can be seen on pump fuel 95 ?
Which version of the mhd .. 5 7 8 ?
From real experience is there a drastic difference in performance from a oem car with both stages ? Does the car still feel dead on the higher rev range limit ?
BMW N54 –
