CK4LIFE said:
Seasons Greeting gentlemen,
So apparently the W204 models have timing chain problems after clocking 100 000km. Mine is on 103k km and it started a rattle noise on start up and I was told without hesitation that it's a timing chain & chain tensioner. Has anyone experienced such a problem and any cheaper place to replace it. Agent wants R27k only for parts. Assistance is highly appreciated.
It is a well documented problem on the M271 motor. Problems usually start from about 80 000km.
If you catch it in time you only need to replace the chain, tensioner and guides. If it however progress to a point where the timing gears get damaged, things start to get expensive. Couple of years ago I was quoted R19k for those gears by MB. You do however get aftermarket gears, but I cannot comment on the quality.
Chain, tensioner and guides only was about R3k excl labor when I did it.
