I’m not talking from experience but from the little that I know it would have to do with a lot of factors. One being charge temps, the lower the temp the less likely you are to experience detonation which means higher boost can be run. Two will be fuel quality ,higher octane = more power. So I would imagine that the internals could handle 800hp if the right conditions are met or the engine could explode at 400hp if the wrong conditions are met. Maybe I’m looking to deep into the subject matter. I’m sure one of the regular techies can explain.:thumbs:
