Note that this setting only changes the main map on the LHS NOT the map on RHS.
I also currently have a F10 2015 version vehicle which does have an individual settings for the RHS. When u push the idrive to the RHS additional options spear for the split screen. The 2016 version does not seem to have this setting. Or maybe I can’t find it as easy as the F10 nav setup.
Eon said:
Ash_Jhb said:
Anyone know how to change the map setting to “Direction of travel” from North oriented”
I can’t seem to find the setting for the small screen.
Easily found for the main screen but not for the small screen in split mode.
Shift the idrive knob to the right and then press on it. That will bring up the different options for split screen. Hope this helps.
Sent from my SM-G930F using Tapatalk
Thanks. The options does not appear as the previous version NAV version. I have a 2015 vehicle where this can be done but not the 2016 Idrive NAV.
