Map settings on F80 display on split screen
Ash_Jhb
Anyone know how to change the map setting to “Direction of travel” from North oriented”
I can’t seem to find the setting for the small screen.
Easily found for the main screen but not for the small screen in split mode.
Eon
Shift the idrive knob to the right and then press on it. That will bring up the different options for split screen. Hope this helps.
Sent from my SM-G930F using Tapatalk
NitroNori
Go into nav settings, and change the map view to Perspective or direction of travel.
Ash_Jhb
Note that this setting only changes the main map on the LHS NOT the map on RHS.
I also currently have a F10 2015 version vehicle which does have an individual settings for the RHS. When u push the idrive to the RHS additional options spear for the split screen. The 2016 version does not seem to have this setting. Or maybe I can’t find it as easy as the F10 nav setup.
Thanks. The options does not appear as the previous version NAV version. I have a 2015 vehicle where this can be done but not the 2016 Idrive NAV.
Ash_Jhb
Got it guys. I found it under the personalize section. The 2016 Nav Version is slightly different from the 2016 version. So all good. Thanks guys.
Mods please close.
