jeff said:Oil & filter changed.
A HUGE thanks to Mike - he dropped off 10 litres of Mobil1 which he kept for me for ages, awesome dude - really, really appreciate it.
Righto's, so after getting messy and changing out the oil I could finally drive the car properly. Here's what I've noticed though.... I can't seem to figure out what's wrong.
CPS, Vanos, Vanos Seals, DSC, Diff, Plugs. I'm a little lost.
Once the car is warmed up and at running temp, whenever I accelerate hard under 4000rpm the car bogs down. The rev's go up but the car doesn't go anywhere. Anything above 4000rpm things are fine and she's pulling like a demon.
I've done a fair amount of reading up and symptoms for the Vanos Seals almost fit this perfectly - except for difficult pull off's in 1st gear. So with that said, I'm leaning towards replacing the Vanos Seals. BUT - intermittently, the car will jerk in 2nd gear. Hard or soft accelerations, 2nd gear seems to make the car jump until I either change gears or put the clutch in - CPS maybe?
Suggestions are appreciated guys! Would like to do as much with DIY. Probably just a good idea to change the plugs anyway.
Check your cats if uve stil got them also exhaust sensors and if u plug the MAF's out does it runn better ? Try 1 for 1 then both. If yes then either a leak behind the maf close to the moter or maf are shot. Easy way to check for leaks is spry carb cleaner on pypes gnd mear injectors and intake ports near the head if idle changes uve got a leak. Hope that helps
