XMAX said:Congrats on an awesome car.
Car looks great.
The F30 330d in stock form is a beast. The MPerformance version is even crazier.
I went to the Stealth Tuning Dyno night in Durbs a few weeks ago. There was a F30 330d Mperformance that made 205wkw +-600nm torque. which is a crazy amount of power for a car with a motor plan...![]()
Magneto said:Ok Plastidip done. Had to go over a few areas as I missed them in the bad light last night. Those of you not sure about how the 403M's would look in black, I hope this gives you a better idea.
Thanks for all the comments on my thread. For now, I am done except for the side decals and sills which I am waiting on stock.
Magneto said:JPAsp said:Did you add the glossifier to the mirrors to get that shine or Is it matte black??
If you want a glossier finish with Plastidip, I have found that you should deviate from the instructions.
Make the first coat a wet coat. Hold the can closer to the target and use the 50% overlap method.
This differs from the usual instructions where they say put a light coat as the base. This will lead to a matte finish, whereas if you make the first coat a wet one, it leads to a glossier finish.
Magneto said:
