M5 V10 Bearings and some more
Peter@AEW
This car has some 88000Kms and was recently sent up from George on Anthony's recommendation.
Thank you Anthony.
Owner has done some work on the exhaust and it is by far the most glorious of soundtracks that it plays.
I collected the car from Ferrari Johannesburg and the salespeople there were in awe of it.
Given the sound of the Ferraris that these guys get to hear on a daily basis it really says a lot about this specimen.
The car was accepted even though the owner is a CHEETAHS supporter.
Exhibit A.
More to follow as work progresses.
Peter@AEW
Mohammed@Auto X-cessorize said:
Uncle Peter as usual good work..... tell me ,is that the throttle actuator? is there a kit for repair on that part?
Yes brought in a few sets. Have 1 set left and more on the water/air.
F21GP
Peter, would you recommend doing this preventatively prior to any errors occurring ? I'm keen on this
Iceman12596
I would do it since the M's Run bearings, will do yours good maneer
F21GP
Sorry, i meant the actuators my bearings are done.
Peter@AEW
Yes it would be better as when the gears wear it will cause issues with the board and that will be a bigger repair bill.
Moe gears are different on the e46
Ratslaaf
I second Peters recommendation. Get the gears replaced as a preventative measure. By the time the gears are truly worn, it starts to cause damage of the h-bridge on the control unit. Then replacing gears doesn't help anymore.
F21GP
Those bearings look way better than mine did at 92000km if those images are of the worst.
