SP33DYV said:
adamr said:
Holy crap ... Thats good consumption ... M3 v8 hovers around the 17-18 mark lol (if I recall) ... This is the smallest m3 motor since the e30 ...
Sent from my HTC One using Tapatalk 2
So does the 1M if driven enthusiastically. Can't see that the S55 motor will be much better. It is essentially the same motor as in the 1M, but with slightly bigger snails and a different intercooler.
Sent from my iPhone using
Tapatalk
S55 vs N55
Stroke:
80mm vs 89.6mm
Bore:
89.6mm vs 84mm
The bore/stroke really sets this engine apart from the 335i (N55) engine and is nothing that a tuned 335i can compensate for. The engine's will act, feel and sound different.
Block:
Completely New and lightweight
Twin-wire arc-spray coating (instead of liners) in cylinder bores reduce engine weight
Turbo size is smaller than 1M turbos.
Maximum HP between 5500-7200rpm (should be 5700-7200rpm)
Maximum torque between 1800-5700rpm
"The turbos run at a maximum of 1.25 bar boost but often less, the electronic brain only cranking up to that level of pressure under high operating temperatures or at high altitude. It means the power and torque figures will remain consistent in the vast majority of conditions. As Vice President of engineering, Albert Biermann, explains, that means a standard M3/M4 will often be as fast on track as a tuned car with a claimed additional 50bhp but no extra leeway to continue to develop that power as operating temperatures soar."
S55 vs N55
From the info ive managed to gather, quite a bit of difference..
