Log review please
akash
Hi Gents
Please can you review the below log done last night.
N54 335i auto
JB4
DP
DCI
Log done on pump fuel. Back end flash to be loaded and secondary cat to be removed this weekend.
Thank you
hoosain
were you at full throttle?
if yes the values indicate otherwise
the car is pulling back quite a bit of timing a backend flash might help here
all other parameters seem fine
FiRi@Rennzport
Also...the correct manner in which to run logs is from 2500rpm till at least 6200rpm in 3rd and 4th gear. Minimum the whole of third. This will give all the info required and paint a better picture.
