Curious to hear how that came about? Don’t these cars not lock when they sense the key is in the car? Or is the boot area a bit too far from the key sensor?
You lock the car ahead of time because then you can just close the boot and walk away. But your mind gremlins wipe your memory of the immediate and you stupidly put your key down because your hands are busy and it is in the way only to forget about that too. 30 Seconds later you are done and pop the boot down safe in the knowledge that the car will not lock with the keys inside. A few moments later memory starts trickling back and you start checking for the key and come to the realisation that you screwed the system and yourself.
That can happen very easily. Happened to me. Its only it was Tops bags and we were on our way to Goudini. Spare key was at home. Fortunately I could unlock the car using the My BMW app.
I did this one many years ago in my Jetta 5.
Also did it a few times with the F30 however the keyless entry system just popped the boot open every time and flashed the hazards.
Have not had a chance to use the BMW app, maybe in future 😎
With the F80 even if you lock the car and then close the boot with the key in it doesn’t latch the boot.
This happened to me before and I was swearing at the car wondering why the boot would not close. Only after the 5-6th attempt I saw the key lying in the boot. Took the key out and it closed.
Or was this a flook? I need to test to see if it was.
