Key fob stopped working
ShaunB
This weekend my key fob stopped working. Its a newish one, was programmed a few months ago when the one key was stolen when they tried to steal my car.
It does not unlock or lock the car or trunk, but I can start the car with it once the vehicle is open....
Does it need new batteries?
LukeHawk
Sounds like it, but your battery should last for quite a long time. You could always take it to BMW and see what they say though, maybe they can reprogram it again or something
ShaunB
My car is out of warranty, I stay far away from BMW :rollsmile:
boost3d
Does it have comfort access/keyless start? If so, the batteries probably need replacing.
The normal FOB is charged when you insert into into the slot in the dash
ShaunB
Its the Normal FOB, does not charge through the ignition either, Will see if I can open up the key.
Dewald Basson said:
From what I have heard you might have to replace the entire car
:tease:
Whooop, just what I wanted to hear :rollsmile:
Ratslaaf said:
Is it an aftermarket key? If so, it's easy to change the battery
The coding was done by Butler Motorsport so I assume it is a aftermarket key.
Ratslaaf
Then its just the battery thats flat. The aftermarket keys open like comfort access keys, youll see a flap on the back.
