Vish*
Kamikaze Collection Coatings now available at Pristine Detailing. I have brought a small selection from their range which includes:
1. ISM Glass Coat which is their premium coating,
2. Miyabi Coating which is the entry level coating,
3. Infinity hybrid Wax (53% carnauba content & 39% glass coating)
4. Overcoat - The Sacrificial layer Coating. OVER COAT is designed to be (easily) applied over the durable base layer coating…which could be ISM COAT, MIYABI COAT, and other brands of glass, ceramic, or polymer coatings. OVER COAT can be applied wet or dry (easy use like a quick detailer)
5. Water spot remover - a good water spot remover designed for use with coatings that won’t damage them in the process. if water spots are relatively new, the WATER SPOT REMOVER by KAMIKAZE will easily remove them. It can be used for either coated, or non-coated vehicles.
Having personally tested the range over the past couple months along with other detailers, the kamikaze range is an awesome range that delivers in looks, durability and ease of use.
http://www.pristinedetailing.co.za/shop-by-brand/kamikaze-collection.html
