Subscribed :thumbs:
Nice stuff here...
I have the chrome rings around my dials but I have it on my e36 3.2L which was a standard ne? if not mistaken.
mine didnt have standard, had to install
I have done some DIYs too like:
Replace airduct/brake vent in front bumper
Fix the the temperature sensor and wires that attaches to the above
Cleaned out the spots wiring, contacts bit worn.
Replace above with HID kit
Replaced all all water and oil breather pipes (7 pipe all together) behind the engine
Replaced Suspension (Coilovers)
Replaced Gearbox and Diff oils
Tightened the Kidneys that kept coming loose
Clean MAF sensor
Things I want/need to do:
Fix climate control unit (this weekend)
Replacing the cover by the wiper/bottom of windscreen (not sure of the name) (this weekend)
Have a look at the map sensor
Gearbox mountings (must check it but im sure its on it way)
The gear boot and the light behind the dials top only(now that you did it but what is involved and how hard is it Karbal? I dont want to try the steering bearing lol)
you can fix the gauge cluster lights without removing the steering wheel. you just need to pickup 3x 07119905358 from the dealer. remove the 2 torqx screws that hold the gauge in place. use a credit card to pull the gauge out. carefully unclip the 3 harnesses. replace the bulbs. reverse - http://www.pelicanparts.com/bmw/techarticles/101-Projects-90-Gauges/101-Projects-90-Gauges.htm
Where can I find the center console i.e. the trim around the gear lever and buttons?
you can get these most scrap places, all the manual 4doors are the same, I got mine from bruces.
And I need gear knob my clips that holds onto the stick broke :nonono:
Hey a pic of my car with the rings, I love it!
