George Smooth said:
Baracus said:
nomercy said:
Hey guy, I'm new here but I've been running jb3 for sum time with no regrets
Last night I loaded the new 5/29 firmware and it makes the car run A LOT smoother!!!
Anyone else outthere done this, would like to hear what you think???
See you running AR Design DP's and water meths? This makes a major difference in terms of what boost you can run at altitude. Are you planning to go pass Snail sometime, am very interested to see what you dyno?
BTW who fitted your AR design DP's for you? Have they brought out DP's for right hand drive vehicles, apparently one of the flanges for the O2 sensors catches in our RHD cars?
I have the first botched set with the flange in the wrong place which I repaired. They sent me a replacement set which is sitting in my garage as I am too lazy to fit and it seems the flanges are in the right place. Should fit them this weekend and will let you guys know.
In regard to the JB3 I think that it is very sensitive to plugs so if your cars have got more than 20,000km fit new plugs and you will be able to run slightly more aggressive maps. In my opinion the other problem with the JB3 at Altitude is that the boost ramps up too much too soon. This kills of the high end power.
Mt father has a big engineering shop and his guys fitted it for me but it was a big mission, not easy at all!
Ill be going to the dyno soon, fitting a bmw perforamce exhaust so car is stock now and I'm getting it back tomorow, so will fit everything this weekend.
I'm running a custom map from terry with the meth, but map 5 daily!!
Good news indeed!!!
Are you running a modified board 15/18ohm? If you are on meth then perhaps you are ready for a new challenge? PM us for a conversation.
No,sir
I'm still stock there, I'm waiting for you guys to do some nitrous on you car first and see how it goes!! I find everything works different here then in the usa!!!
So ill wait for some local experts/you to do it first, then we can talk!!!
And terry is planning big things for jb3 users in the next 2-3 mounths!!!
