It's just a blue box
Sankekur
I guess better late than never is the only apt way of describing this. So late 2016 early 2017 a decent e30 crossed my path, or I crossed the path of a decent e30, either way as the price was decent I acquired it, seeing as for some reason I had wanted to get an e30 for some time.
So the details, its a 320i, mileage was just over 130k km when I got it and it is sitting on 135ish k km at this point. It is a 92 model if I recall correct. The colour is lazurblau metallic, i think. I am the third owner, the second owner had the car from around 96.
Some photographs:
uc
uc
uc
uc
So far I have done the following:
-replaced lower control arm bushes
-replaced the cam belt
-replaced the cam belt tensioner
-replaced the fan, powersteering, and air conditioner belts
-replaced the thermostat
-replaced the waterpump
-replaced pipe between waterpump and thermostat
-replaced cam shaft seal
-replaced cam shaft holder seal
-skimmed exhaust manifold
-replaced exhaust manifold gaskets
-replaced exhaust manifold studs and bolts
-replaced valve cover gasket
-adjusted valve clearances
-replaced intake boot
-cleaned throttle body and ICV
-replaced injector o-rings
-replaced fuel filter
-replaced rubber fuel lines
Thank you for watching.
yush1
Great car. Mileage is really low for the model. Any plans to mod or are you keeping the stock look? Personally I would keep the stock look. There aren't many original one's around.
Sankekur
Thank you for all the kind words gents, it is really appreciated.
I agree the plan is to keep the look stock, I actually don't have any plans to change anything really. This being said I did change the wheels because it needed a change in tires and set of wheels with tires came up for sale that I though would look good, well pics will follow so I will each judge for themselves.
SubLoaded said:
Very nice. Out of interest - how much has the work on it cost you so far?
Up to this point I have spent R4347.06 on the car, it should however be noted that this does not include any labour as all the work was done by myself, and at times some unfortunate sucker that happened to be in the wrong place at the wrong time.
Edit: I will also add here that most of the work was not really needed, for the most part only the change in seals/gaskets were needed, the rest was just "peace of mind" maintenance.
DoctorJ said:
I remember this trip. Was when a certain shadowline made it's way to Gauteng.
Of course, it would be this shadowline for those that don't know it:
uc
Twinz
Forum - Support
The box looks spotless....cool story and great find at that mileage :bravo:
Sankekur
Thanks gents.
ZaynM said:
Looks Great!!
Any interior pics?
Unfortunately no, for some reason I always neglect to take photos of interiors, but at some point I will.
Jeremy.d said:
So when are you putting the m50?:biglol:
I was actually thinking 2jz :fencelook:
Clint@MMS AUTO
Lovely unmolested E30... I really love lazurblau... its an amazing colour when nicely polished... all the best , keep it clean :)
