Details below, I will post the contact details later., but for those on Facebook, have a look for CAT (Cars against Etolls) look for Eugene Kriel, he's the contact guy, supplier is in Menlo Park PTA.
Our most popular DashCam is the R-300, besides general functions of the DashCam which all them have, this model has three main features:
· Built-in dual camera, bringing convenience for you to take photo and video at the front and in the cab of your vehicle.
· GPS module can record the whole driving track. Using specialized software, you can see the video on your computer, at the same time connect to Google maps, driving route shows on the map and you can trace the route of the vehicle.
· Built-in gravity sensor G-sensor can record the gravity sensing information. Using software, you can see the video on your computer, at the same time read the gravity sensing date to trace accident and abnormal circumstance occurred in the running process.
Specifications:
1. Sensor: 2 CMOS Sensors
2. Display: 2.7'' (16:9) FTT LCD panel or TV out. TV out support NTSC & PAL.
3. Audio: Support recording and playback
4. RTC: Install system clock inside
5. Video Size: 1280 x 480 30FPS (2CH Record), 640 x 480 30FPS (1CH Record)
6. Memory Card: SDHC Class 10 32GB – 64GB, proprietary file format, need to use the player to start the movie
7. Support GPS module
8. Support G Sensor
9. Battery: Built-in lithium polymer battery
10. Lens: Front lens with ultra wide angle of 140 degrees; back lens with ultra-wide-angle of 120 degrees
11. System Requirement: Windows 2000/XP/Vista/windows 7 and 8, MAC OS x above 10.3.6
12. TF memory card slot: Micro TF – for Micro SD Card click here ---->
http://www.phytotekonline.co.za/ProductDescription.aspx?id=2302685
13. Automatically starts recording on ignition of your vehicle and automatically switches of when you switch your vehicle off.
Package Contents :
1 x 2.7" HD DVR
1 x Car Charger
1 x GPS module
1 x Mount
1 x Clip
1 x User manual
cid:
[email protected]0B7E820
R1299.99 incl VAT ex Delivery
