Was bored so took it upon myself to clean up the sump.
After clean
Prep for the spray
After the spray
New oil filter housing was also treated to some love
Prep
After spray
More to come
Previous post was during the week.
The below is from today. I have dropped off my power steering lines to be fixed up. Should get them back this week.
Due to all the oil leaks. I decided I need to kinda sort it out before the new sump goes in. This is what I am working with. It’s like thick cake due to the sump ps leak and valve cover leaks
Before
After
Still need to do a lot of work on the grime stuck everywhere.
Also found that the pin that holds in my steering rack was never tightened from the guy that put in my m3 steering rack.
I also found why my sump was leaking. They never removed the old gasket sealer properly and just put new one on top. Also the way they applied gasket maker was not done correctly. And they didn’t put in all the bolts. The old sump easily weighs 3 times the oem sump. And it’s a kak design.
Check how badly the gasket maker was applied
Awesome quality sump lol made of steel. So freaked heavy
OEM vs kak sump
Taking time to do all of this as I am only working on the car on weekends during the day. I just want it finished. Need to remove the subframe so I can put in the sump as it doesn’t fit without removing it
Thanks for viewing
Before
After
OEM vs kak sump
Thanks for viewing
