ebrahim.achmat said:A) Never park yourself in tight at intersections
B) Smash n grap tint ? or leave window open by 1 cm , reduces the risk of window shatter
L~C~G said:ebrahim.achmat said:A) Never park yourself in tight at intersections
A) This is a common theory that gets thrown around a lot and whilst is has merit in some cases, anyone who advocates this as any serious means of avoidance has never actually driven a car in JHB in my opinion.
90% of the time it is totally and utterly impossible to not be boxed in at an intersection and if someone decides to target you at that point there is nothing you can do.
B) I have always found window film to be a huge plus but it has to be so dark that you cannot see inside and that is illegal. Driving at night is also very difficult with that film on, you really cant seem much when reversing in the dark.
When these guys swing a spark plug on a piece of string / tyre spanner / steel pole etc at your window it is going to break whether it is closed or open. So dont think you are safe because your window is slightly open.
Smash and grab film will keep the window in tact so you can GTFO, but it doesn't stop bullets so unless it is so dark that they cant see you it has not benefit in a Hi-Jackingvylint said:L~C~G said:ebrahim.achmat said:A) Never park yourself in tight at intersections
I always thought that having 'anti-smash n grab tinting' would negate your window from smashing in. I'm expecting mine to break but at least hold in place long enough for me to get the hell out of there!
:argh:
If you have a BMW you have an aircon. Close your damn windows.Dippies said:Latest craze also is that they use Swimming Pool Acid to spray you in the face if your window is open.
L~C~G said:Smash and grab film will keep the window in tact so you can GTFO, but it doesn't stop bullets so unless it is so dark that they cant see you it has not benefit in a Hi-Jackingvylint said:L~C~G said:ebrahim.achmat said:A) Never park yourself in tight at intersections
:argh:
And if you have a Good BMW you have a sun roof. Open that rather if you must.
